May 01, 2025, 04:52:32 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: Headlight... « previous next »
Author Topic: Headlight...  (Read 4070 times)
88formula
« on: May 27, 2010, 09:40:26 pm »
So my left headlight has dropped...
now i know the 88s headlights are different from the rest, but what's the easiest / best way to fix it. its on the drivers side and its a pain to have to lift it manually when need be.
finally i have some of the extra horse power i've been looking for with a chip and performance with new rims and tires... then the light goes...
well i hope someone can help me out
88formula
« Reply #1 on: May 27, 2010, 09:42:14 pm »
now that i think of it, it was down before too....... i guess i forgot about that cause it started working again but thats what the sound was when i put them down
« Reply #2 on: June 03, 2010, 01:00:04 am »
It's likely the parts inside the gear.  If you open up the mechanism you will see what's going on.
Mine did the same thing.  I replaced the broken inner part with rubber.  There are many write-ups about this.  Try doing a few searches on a couple forums and you'll have a good idea how to do the fix.
FIERO-JOE
30 years old!!
« Reply #3 on: June 08, 2010, 12:32:32 pm »
well i have an 84 so this may not be totally accurate for you BUT.....
 look for a single black wire with a connecter in the middle.. unplug that wire and it will stop the motor from working.. now that will leave the light in the up position, light on or off.. now i know that looks horrible..  so.. for permanent fix.. pull out the whole motor and light..
remove the motor part.. and you will have to drill out the rivits.. to open the housing..
the main problem is the big gear looses teeth and will start to grind.. but the good thing is, that large gear only turns 180* so to fix that.. you just rotate that large gear until the stripped part is not being used to move the light and it will solve the problem.. now you will have to go to Home depot.. and get small nuts and bolts. to close the houseing..
the only other is to buy(on ebay) a new replacement gear.. both will work great
have fun with that,,
joe
falcon_ca
« Reply #4 on: June 08, 2010, 05:53:05 pm »
Fiero-Joe, 84-86 headlight system is different from 87-88, but you solution is the one for 84-86.
With 87-88, usually, it is the 3 bushings.
Rodney sell everything you need for 87-88: http://rodneydickman.com/catalog/product_info.php?cPath=32&products_id=231
You can sometime find those bushing on eBay.
http://cgi.ebay.ca/87-88-Pontiac-Fiero-GT-Headlight-Motor-Repair-Kit-x2_W0QQitemZ360270341235QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item53e1c92473
Restoration Formula
4.9 Ongoing project
88formula
« Reply #5 on: August 25, 2010, 11:39:28 pm »
now more than a month after the fix, the headlights stay down. I got the metal gears and it seems like a jam, because i can get them down by loosening the motors by hand then completing the rest with the motor.
anyone else have this problem?
88formula
« Reply #6 on: August 25, 2010, 11:42:22 pm »
mind you this doesnt happen every time...
falcon_ca
« Reply #7 on: August 27, 2010, 10:11:19 pm »
did you also change th three little plastic like bushing?
Restoration Formula
4.9 Ongoing project
88formula
« Reply #8 on: September 02, 2010, 10:32:23 pm »
yes
falcon_ca
« Reply #9 on: September 03, 2010, 11:11:27 pm »
Is the motor hard to turn by hand?
Sounds like the motor is stopping like if the mecanism was completely down.
Restoration Formula
4.9 Ongoing project
88formula
« Reply #10 on: September 03, 2010, 11:26:54 pm »
well yes that would make sence. it just confuses me why it does it only sometimes... I guess it just randomly gets jammed...
