May 02, 2025, 10:27:48 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: Manifold is red hot!! « previous next »
Author Topic: Manifold is red hot!!  (Read 3003 times)
mudslut
« on: September 13, 2002, 08:41:47 am »
I have an interesting problem with my 2.8 Fiero. After idling for maybe 10 min max, the manifolds turn a bright glowing red and are extremely hot!!
Is this a sign that the timing is off??
It has been hard to start lately when its cold as well...
MAybe its too lean...
ANy ideas???
Huh
fiero1
dark-rider
« Reply #1 on: September 13, 2002, 08:46:04 am »
Hi,i read @ spoke to GM that the manifold will get red hot @ to them this seems to be normal but as your starting problem i can't help you but check with Gary im sure he will have the info your looking for.
« Reply #2 on: September 13, 2002, 08:10:47 pm »
The manifolds tend to glow around the welded flange
sometimes as the metal is fairly thin.
If they are really glowing you may have a vaccum leak somewhere.  This should also cause a higher than normal idle. s/b about 800 rpm give or take (auto in D). Most likely a big leak would be in the tube from the egr to up under the plenum.
Timing off is another guess, although the 2.8 is not really known for stretching or jumpng timing chains. It might also make a hard to start situation.
I have a hard start now too, I put it down to a leaking injector which allows the fuel to drip thru during the night. My fuel consumption is pretty bad as well.
fiero1
dark-rider
« Reply #3 on: September 13, 2002, 10:50:49 pm »
Hey gary i was reading the possible high idle mind idles high cold or hot around  1000 rpm the EGR tube on mine was cracked but i got it wekded so i wondering now that you mention it if it's still leaking oh well an other winter project...lol.thx Grin
Wrench
« Reply #4 on: December 29, 2002, 11:33:10 am »
Don't know if you got your hot manifold fixed. Check the air filter. If it's wet and freezes, it will prevent air flow and run rich as hell until it cools down and the ice melts. Change oil regularly and make sure that the crankcase ventilation is working well.
