May 05, 2025, 02:12:13 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: Well it finally happened... « previous next »
Author Topic: Well it finally happened...  (Read 3017 times)
A.K.A
« on: October 27, 2003, 12:08:13 pm »
I have an undistiguishable (spl?) noise commin from the duke! It started on sat on the way to work....SO I have begun dissasebly and am pointing to the starter not truly dissengaging..
But I better start with the symptoms....weird "Paint can rattle" @ 1700 rpm...AND NO OTHER!!! I cannot reproduce it unless there is one on the gas, one in the "trunk"  It matters not if there is load on the driveline or not....
checked the torque converter bolts (where they attach to the flywheel ;P ), valve train and ALL my accessories...
any thoughts?
a.k.a
« Reply #1 on: October 27, 2003, 01:59:07 pm »
Heat shields?
Improperly secured exhaust system?
:insert random component name here:   Huh
All I can do given the description, is guess.  Best bet would be to put her back together, hold at the desired RPM, and probe about the engine compartment with a stethoscope.  Be sure to check from underneath as well as above!
After you isolate the area from which the noise is likely coming from, then start taking it apart.  Smiley
« Reply #2 on: October 27, 2003, 04:38:59 pm »
coming from an ex Duker.. Me votes valves. Smiley  probably have a loose rocker. take the valve cover off and check. not a big deal. Smiley
A.K.A
« Reply #3 on: October 30, 2003, 08:53:43 am »
figured it out...
I need a starter (35 bucks), what is happening is....starter is not fully dis-engaging and kinda rubbing on the flywheel
one time, long....long ago in a galaxy far far away, some1 stripped one of my bolts and made the starter NOW have a bit of an angle to 'er
***whew***
nothing serious...excellent!
BootMachine
« Reply #4 on: October 30, 2003, 03:27:14 pm »
I thought you had a spun bearring!
A.K.A
« Reply #5 on: October 31, 2003, 11:34:51 am »
yea man! what a relief eh?
