May 05, 2025, 05:25:29 am
Ottawa Fiero Club Forum  |  Buy/Sell/Trade  |  Parts  |  Topic: '85 2.8 starter and alternator f/s « previous next »
Author Topic: '85 2.8 starter and alternator f/s  (Read 3153 times)
« on: August 19, 2003, 07:00:57 pm »
hi all
I am putting a bunch of stuff up on ebay and thought I would see first if anyone locally wants or needs a starter or alternator for a 2.8.  I am doing that engine swap and so don't need them, and they worked fine for me.  I am asking $25 each and they would make exc spares I think.  The starter in particular seems to be a trouble item so a spare may not be a bad idea.
Let me know soonest!!! thanks.
Tiberio and Tyler; could you send me an email when you get a chance?  (trying to get some stuff out of the garage..........  Wink )  thx!! Grin
« Reply #1 on: August 20, 2003, 11:35:09 am »
Update:
the starter is sold;
 but I am trying to determine if the alternator is from an A/C car ore not.  (my 2.8 is a swap-in to replace a 4 cyl)
If anyone knows how to tell or what to look for could you let me know pls?  I could post a pic if that might tell the story.
thx! Smiley
« Reply #2 on: August 20, 2003, 01:42:17 pm »
looks like it is a 63 Amp alternator; that would be the NON a/c unit I am sure; I think the A/C unit would be 110 or something considerably higher.  I am also guessing a bit but see the pic and I believe that 63 is a standard output for them.  The last few characters in the top line should tell the story.
If questions pls email direct or here.  Thanks
Worked fine on my 2.8. .... Grin
stroker
« Reply #3 on: October 05, 2004, 09:30:27 pm »
with a/c you will read 78 instead of 63 so that is 78 amps
marc the stroker.
stroker
« Reply #4 on: October 08, 2004, 10:20:48 pm »
i was wrong with the 78 amp i checked today and it is 94 amps witch lester catalogue system calls a 7294 for 84-87,it's the 12si series
and for 88 you get an 105 amp witch is the newer batch called the cs series with the newer style connector.
marc the stroker.
« Reply #5 on: October 21, 2004, 05:11:28 pm »
well the alternator is still available for anyone who needs one; let me know.
I have a bunch of misc other stuff available; rear coil 'cooling' fan and pipes/ducts; radiator; I guess I will have to go thru it all and list it properly.
 Grin
