May 04, 2025, 03:32:12 pm
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: Wiplash driving « previous next »
Author Topic: Wiplash driving  (Read 2648 times)
Rebel
« on: July 18, 2003, 07:20:58 pm »
Any suggestion where to go now
Here are the symptoms
Pulsing in drive mod or more will I decelerate, seem to run ok under load you get whiplash will light pedal pressure
Here with I have done
New plug
New dist cap
New fuel filter
New wires
New coil
Replace computer, map, oxi, and sencer
Decarbonized in clean fuel injector still not convinced it not pulsing
Just thought I put out to the form for any ideas will be welcome
FieroRebel
Marcel   Have a good day all J
« Reply #1 on: July 19, 2003, 12:52:30 am »
motor mounts... although that would be more evident on acceleration and  when you get off the gas,
If it's auto could be the lockup solenoid(torque converter)
« Reply #2 on: July 21, 2003, 08:11:01 am »
I second that motion.  Wink
You can do an in-driveway check to give you a general idea of whether or not the mounts are the problem, and which ones.
Find some level ground, it's easier.  If it's an automagic, put it in park; if manual, use reverse or 1st without engaging the parking brake.  Open the decklid, now push/pull on your favorite body part in an attempt to rock the car and observe.
If the top of the motor reminds you of your grandma's favorite rocking chair, generally the first place to look is at the dogbone bushings.  The bolt holes through the bushings should be snug & round, not elliptical.
If the bottom of the motor looks like it's trying to move about, you may have worn transmission, lower engine mount, or even the cradle bushings.  20-year-old rubber parts have a way of stretching & drying out.
