May 02, 2025, 01:28:48 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: DIY Ghetto 3800 Intake « previous next »
Author Topic: DIY Ghetto 3800 Intake  (Read 2493 times)
Church
WWW
« on: October 02, 2011, 05:36:13 pm »
Ghetto 3800 intake. What I did was I sawed off the bit from the stock fiero intake piping, shaved the inside of the FieroStore K&N Intake filter and simply attached the filter side of the stock fiero intake tube to the throttle body. Just a temporary mod till i have enough money for a Weapon R intake.
And yeesss, i did clean off the rust before putting it on  Wink.
Dan
« Reply #1 on: October 02, 2011, 09:28:55 pm »
Save some time and money and go with a good K&N filter in the wheel well and use ABS piping to connect to the engine, cheaper and does not conduct any heat or just use the factory V6 air box and get rid of the restriction in the wheel well with a piece of tubing.
If you need any other help with the swap let me know. Dan
« Reply #2 on: October 03, 2011, 04:20:58 pm »
That's Ghetto all right....how long do you plan on using it?  I'm worried that it might just fall off during use or have a bad seal since there is nothing hard to clamp to.
Try putting a small section of pvc pipe under the clamp if you haven't already.  That should get you more time.
Church
WWW
« Reply #3 on: October 05, 2011, 02:18:44 pm »
Thats exactly what i jut did now! Smiley
