May 01, 2025, 04:51:45 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: Starting problem « previous next »
Author Topic: Starting problem  (Read 1805 times)
drebac
« on: October 08, 2010, 02:05:56 pm »
I have a 85 fiero 2.5l 5 speed manual transmission, the car was running but its seem after the engine is warm it cuts out for a while if you let it cool down it would start but now the starter turns but the engine does not fire.  The fuel filter was replaced, fuel conical spray seen.  ignition wires, cap and rotor replaced no spark at spark plug. input to ignition coil checked 12v seen at input side when ignition on.  checked the coil input 1.5ohms output hv 8000 ohms.  In my manual there are no wiring diagrams does anyone know where i could get one.
« Reply #1 on: October 08, 2010, 11:38:33 pm »
http://www.fieronews.net/fusion/downloads.php
