May 01, 2025, 10:26:24 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: GT Quarter windows « previous next »
Author Topic: GT Quarter windows  (Read 2389 times)
dimeadozen
« on: June 10, 2010, 01:28:38 pm »
I have a set of GT quarter windows and I thought they would bolt up in the back the same way as the Se triangle windows did inside the pillars.
But I see that they don't...
Are they just glued? can I yankem?
« Reply #1 on: June 10, 2010, 07:46:46 pm »
On the notchies there is a bolt that comes in through the side that needs to be dealt with by removing the interior trim piece that the seat belt goes through. Dan
« Reply #2 on: June 10, 2010, 10:11:24 pm »
The GT's are held on by two sided tape. If the windows are still good I would use a hair dryer to heat them a bit when your yanking them.
dimeadozen
« Reply #3 on: June 10, 2010, 11:27:05 pm »
Nice. Thanks guys. Gonna rip em out tomorrow
« Reply #4 on: June 12, 2010, 12:24:11 pm »
At some point ( I don't know when) GM started to put a wire built into the installaion.  You pull the wire which cuts the tape.  Then when you re-install you put an new wire back in.
