May 02, 2025, 04:55:33 pm
Ottawa Fiero Club Forum  |  Buy/Sell/Trade  |  Parts  |  Topic: parts 4 sale that can be used for a 3800 swap. « previous next »
Author Topic: parts 4 sale that can be used for a 3800 swap.  (Read 2466 times)
Joe Fieroshop
« on: September 16, 2008, 08:20:39 am »
I have a few things that might help some one with a 3800 swap that is on a budget. first I would like to say that the items are used and are still in very good shape and very usable. I have a stage 4 clutch disk and pressure plate for $250.00 this clutch is good for 350 hp, actually anyone can use it in there fiero, it's from a 5 speed but you can use it on a 4 speed as well. (sorry no bearing). I also have a 94-95 3800 PCM OBDI that is already programed for a manual trans.  The vats is removed, the auto tranny codes are removed the injector size is changed to 42lbs, this PCM was made for any 3800 with a turbo to run at 10 psi. Items like EGR and purge are still programed, no more 2ndary O2 sensor. Other things have also been changed too. This is selling for $250.00 as well. I also have 6 slightly used 42.5lbs injectors for  $200. I have a brand new TurboXs blow off valve type H, its a $125.00 and i have one more item. It's a flowmaster Camaro muffler that has been shorten to fit in the stock location, it has the 2.5 or 3 inch inlet with the twin 2.5" out lets, this is also $150.00
If any one has any questions just feel free to ask.
Thanks
Joe
« Reply #1 on: September 16, 2008, 11:54:54 am »
What diameter is the clutch?
How many pucks are on the disc, and what materials are they?
Joe Fieroshop
« Reply #2 on: September 16, 2008, 09:27:45 pm »
it's stock fiero size, it's a 4 puck and ceramic..
joe
« Reply #3 on: September 17, 2008, 08:07:03 am »
Thanks Joe... one more question.  Is the hub sprung or solid?
Joe Fieroshop
« Reply #4 on: September 17, 2008, 07:34:38 pm »
yes it is.
« Reply #5 on: September 18, 2008, 10:03:16 am »
 Grin  Grin  Grin  Grin  Grin  Grin  Grin  Grin
Joe Fieroshop
« Reply #6 on: September 18, 2008, 09:40:07 pm »
Sorry it's a sprung hub..... Cheesy
