May 02, 2025, 06:01:42 pm
Ottawa Fiero Club Forum  |  Buy/Sell/Trade  |  Parts  |  Topic: V8 kits 4 sale « previous next »
Author Topic: V8 kits 4 sale  (Read 2087 times)
salmonfieros
« on: September 30, 2007, 10:28:19 pm »
I am from Brockville/Gananoque Ontario.
I am manufacturing V8 kits for automatic fieros.
This kit allows you to bolt a 350 chev motor into the rear of a automatic fiero.
The kit includes:
1. the adaptor plate to mount the motor to the fiero transaxle.
2. the front lower motor mount plate, which is also drilled to hold the stock fiero A/C pump.
3. the altenator bracket to either hold the stock fiero alt, or any chev alt.
All plates are CNC machined, and epoxy painted black.
It takes me 5 business days to make them up, as i do them after work!
I have pic's upon request.
$500.00 canadian for all of the plates, making up one full set.
Chris
lercs
« Reply #1 on: October 01, 2007, 07:13:31 am »
I wouldn't mind seeing these and I have to ask why wont it work on the manual tranny?
salmonfieros
« Reply #2 on: October 01, 2007, 09:23:57 pm »
manual transmission requires an aluminum plate that is half the thickness.
With a manual set up, you also require a special flywheel.
I have not made any of these kits yet.
The automatic kit, all you need is to space the torque convert away from the flywheel using 1" thick spacers.
Basically a pc of 1" steel with a hole drilled in it.
Very easy.
what is ur email.
chris
