grinder
« on: May 31, 2007, 01:10:04 pm » |
The insulation blankets around the battery area of my car are pretty ratty. Does anyone have a source for new material or replacements? Also the guy that had the car before me did quite a butcher job on the wiring in the engine compartment. I wanted to build a few new harnesses but have not been able to find only the connectors. Places carry pig tails to splice in but not just the connectors and pins. Any ideas? Thanks.
grinder
« Reply #4 on: May 31, 2007, 09:52:43 pm » |
Hi Kevin, It is a 1984 with 2.5l engine. Garry
grinder
« Reply #5 on: May 31, 2007, 09:54:37 pm » |
BTW, thanks guys for the link to the insulation blankets and lead on the pins. Garry
grinder
« Reply #7 on: June 08, 2007, 10:18:59 am » |
Hi Kevin, Is the 86 harness from a 4 cylinder installation? Thanks, Garry
grinder
« Reply #9 on: June 08, 2007, 11:07:17 am » |
Kevin, I will double check my manual tonight when I get home but I think that it should work. How can I hook up with you to get it? Garry
grinder
« Reply #11 on: June 08, 2007, 11:45:14 am » |
Thanks for the info. I need to get a look at or get some pictures of the engine compartment of an 84 with 2.5 engine that is in good shape. By the looks of my engine and the wiring the previous owner must have had the engine out for some work and wasn't too careful about how everything went back in. Wires chafing and taped up, etc. I was hoping to get out to see everyone last weekend and check out a few cars but spent all day Saturday with my son at the rink for lacrosse. Garry
« Reply #12 on: June 08, 2007, 04:37:29 pm » |
The location of the C500 connector is not the only difference in the 84's they also used different connectors to feed the gauges. The C500 is the same connector though and pins can be moved around to match every thing up. I have a completely stock 84 fiero with the 2.5 still in it if you want I can take a few photos for you just need to know what you need to see. Dan
grinder
« Reply #13 on: June 13, 2007, 11:16:12 pm » |
Hi Dan, Looking for a couple of good photos of engine compartment, especially location and routing of harness. Trying to find out what else may be missing or not installed properly before running it again. Thanks, Garry
