May 04, 2025, 10:44:45 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: 4 speed shifter « previous next »
Author Topic: 4 speed shifter  (Read 2394 times)
« on: September 16, 2006, 02:20:44 pm »
Was fooling around with an 84 Fiero 4 speed shifter, sort of redesigned it to work with a shifter knob off a 70's Trans Am. Was going to use it before I decided to just get a 5 speed instead, now I no longer need it so any one in need of a 4 speed shifter like this. Will get a photo up later. Dan
« Reply #1 on: September 16, 2006, 03:19:55 pm »
If you're talking about that little short one you showed me last weekend, I'm pretty sure I can find a home for it.  Smiley
« Reply #2 on: September 16, 2006, 03:25:41 pm »
Anyone who has a Fiero shifter and wants to shorten it should do this.............
Grind (finally) the welds off the shifter shaft.  Throw away the fat shifter that few knobs fit.  Cut a suitable shifter off at your local stablishment and bend to suit and weld back on the Fiero unit.  Voila! Aftermarket knobs galore.
« Reply #3 on: September 16, 2006, 06:46:44 pm »
I would listen to Gary if there is one thing he knows about its knobs. Yes Don its the one I showed you will set it aside till next time I see you. Dan
« Reply #4 on: September 16, 2006, 09:03:03 pm »
Thanks!   Afro
I switched the shifter in the '85 to the shorter '84 shaft a while back, but that one's still too long for my liking.
