May 04, 2025, 05:52:34 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: trunk switch not working « previous next »
Pages: [1] 2 Go Down Print
Author Topic: trunk switch not working  (Read 5590 times)
lacelles
WWW
« on: September 07, 2006, 03:01:32 pm »
Small problem
When I press on the trunk switch, I hear a buzzing noise under the dash and the trunk doesn't open.  Huh
Any Idea ....
http://www.lacelle.ca
« Reply #1 on: September 08, 2006, 07:56:22 am »
Remove the trim panel under the dash, and you'll find a relay under there somewhere.  If you can't find it, hold the decklid release button and look for the part which is buzzing.  Smiley
Try swapping that relay with the horn relay from the "convenience center".  If the decklid release works after that and your horn doesn't, let me know and I'll bring a replacement along for you tomorrow.
lacelles
WWW
« Reply #2 on: September 08, 2006, 02:13:01 pm »
Thanks
I will try that tonight.....
lacelles
WWW
« Reply #3 on: September 08, 2006, 11:03:26 pm »
Hi Don
Well, I did found the trunk relay.  The buzzing noise is coming from the relay...  I didn't try the horn relay replacement.  But one thing I know that my solinoid is working because I use my alarm system remote and I'm able to open the trunk.
Don can you bring your spare relay with you tomorrow?  I will buy it from you.
Thanks
lacelles
WWW
« Reply #4 on: September 08, 2006, 11:09:25 pm »
I'm also looking for a trunk light with the plastic casing, mine is broken???
« Reply #5 on: September 09, 2006, 08:01:55 am »
Found the relay; couldn't find any decent trunk light lenses though.  See you this afternoon!
lacelles
WWW
« Reply #6 on: September 13, 2006, 10:43:35 pm »
The relay was not the problem  Angry
Also still looking why the light stays on in the car ......  Sad
« Reply #7 on: September 13, 2006, 10:46:35 pm »
Would dirty contacts or a short cause the light to stay on?
« Last Edit: September 13, 2006, 11:18:14 pm by MacPhail » Logged
« Reply #8 on: September 14, 2006, 09:55:05 am »
Test the switch on the instrument pod next.  Pull it out, disconnect, and short the orange wire to...   crap, can't remember the other color and the site with online diagrams I had bookmarked is down.  It should be in the back of your friendly neighbourhood Haynes manual though.   Two wires run the switch's illumination, the other two are a +12v supply and the feed to the relay.
Which light?  I remember you mentioning it at the last GTG, but I didn't catch which light it was....
lacelles
WWW
« Reply #9 on: September 14, 2006, 10:48:14 am »
Hi Don, the lights are the 2 middle lights on the roof light.  Also if I press on the switch to open both side, they don't work.  I took the roof light off, and everything looks ok inside.
« Reply #10 on: September 15, 2006, 02:34:53 pm »
Two more questions then...  Smiley
First, have you checked whether or not you've accidentally rolled the instrument panel dimmer switch up in to the position which turns on the courtsey lights?
Second, by any chance did the lights start staying on around the same time as the decklid relay started buzzing?
lacelles
WWW
« Reply #11 on: September 15, 2006, 04:49:34 pm »
Hi Don,  No, That's the first thing I have check, the dimmer switch
Yes, Don, the decklid relay started buzzing around the same time.
« Reply #12 on: September 16, 2006, 09:07:08 pm »
Strangely co-incidental, that is.  If you haven't done so already, double-check that you haven't blown the CTSY/LID fuse.
Failing that, start looking for either a failed ground or something which is shorting to ground (and shouldn't be).
« Reply #13 on: September 17, 2006, 03:01:41 am »
Just follow the power and check for it.
lacelles
WWW
« Reply #14 on: September 19, 2006, 10:16:59 pm »
WELLLLLLLLLL  Afro
After taking apart all door jam switch, hood jaw switch, check every wire under the dash, reading wiring diagram (tried to understand them  Embarrassed).  After 2 hours of frustration, decided to do some searches on different forums... Everything goes back to fuses..  Decided to check the fuses...  Should have done that the first time..  Embarrassed
Yes fuse 25 amp CTSY/LID was burnt....  Huh Shocked Sad Angry Embarrassed
Now I still have about 1hour work to put everything back together...
Well f@#$#k it for tonight I'm going to bed....
Pages: [1] 2 Go Up Print
