May 04, 2025, 03:00:58 am
Ottawa Fiero Club Forum  |  Buy/Sell/Trade  |  Parts  |  Topic: Northstar Swap For sale , almost everyhting you need. « previous next »
Author Topic: Northstar Swap For sale , almost everyhting you need.  (Read 2462 times)
Slammed Fiero
« on: September 05, 2006, 01:40:28 pm »
I blew up my Northstar , and in the driveway it sits. I don't have time to do this swap justice , so I think i am going to try something different and a little more basic
You get
Blown Northstar (I assume it's a spun bearing)
Holley Commander 950 with wiring harness. Basically a plug /play and tune setup. You will need to connect approx 8 wires to get it running.
Modified cradle. All mig welded , bolts up to northstar. You get the little adaptor to bolt the northstar directly to a getrag
Spec Stage 3 Clutch and Aluminum Flywheel.
Mandrel bent Exhaust with twin resonators and supertrapps if you want the,..the car is loud
Upper dog bone brace with heim ends.
You need:
Fiero (duh)
Getrag Tranny . I am keeping mine since I have around $1000 into a rebuild.
Time
All 84 to 87 Axles , struts , ect..ect
I put aprox 2500kms on the swap , drove it from Kingston to Oakville a few times. Just with my life I don't have the time to  Rebuild the motor and likley won't start working on it until next winter. I would rather free up some cash for my Corvair turbo project at the moment.
Looking to get $2000 For the whole deal. Will be available in january.
« Reply #1 on: September 06, 2006, 12:53:09 pm »
That's too bad dude.  I don't even know what to say, I feel pretty bad about it and it's not my car.
Good luck with the Corvair, that car's going to rock.
Bradtholomew
« Reply #2 on: September 06, 2006, 09:16:00 pm »
I may be interested come January...
Brad
Slammed Fiero
« Reply #3 on: September 07, 2006, 01:26:37 pm »
You will also get 2 sets of heads. One set is ported professionally , one  set stockers.
Slammed Fiero
« Reply #4 on: September 07, 2006, 02:28:50 pm »
You also get a spare oil pan , spare intake manifold , New rods , used pistons. A few extra sensors , Throttle cable bracket.
