October 31, 2024, 08:03:51 pm
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: 92 Z24 Getrag « previous next »
Author Topic: 92 Z24 Getrag  (Read 1404 times)
« on: June 02, 2006, 01:52:12 pm »
Any one know if the Getrag 5 speed in a 1992 Cavalier Z24 is one of the trannys that can be used in the Fiero along with the Dickman adapters. Dan
« Reply #1 on: June 02, 2006, 04:24:28 pm »
http://www.rodneydickman.com/getraginfo.htm
Cav 87-89
Don't know if this part applies:
Other 1987-94 Getrag's have a different internal slave cylinder/arm set-up. On these Getrag's the slave bolts directly to the bell housing and the release arm is inside the transmission. I currently offer an adapter to use these later year Getrag's to be used in the Fiero. Cars that use this type of Getrag are typically the Grand Prix, Grand Am, Etc. Most, if not all, Quad 4 Getrag's have this internal arm set up.
« Reply #2 on: June 02, 2006, 08:14:32 pm »
Unfortunately it doesn't mention any thing about a 92 Cav Getrag. Will contact Dickman and see what he says. Its kinda a good deal I took a few old tranny's that were laying around to the wreckers and while there saw the Z24 so I asked about it. He says it works and if I remove it I can have it, not too bad a deal. Dan
« Reply #3 on: June 05, 2006, 11:29:40 pm »
I asked him about the newer slaved getrags a while back.  He said he did have an adapter for them.
