May 04, 2025, 04:11:43 am
Ottawa Fiero Club Forum  |  Buy/Sell/Trade  |  Parts  |  Topic: A few odds and ends required... « previous next »
Author Topic: A few odds and ends required...  (Read 3004 times)
34FieroGT
This, is my BOOMSTICK!!!
« on: March 31, 2006, 07:26:24 pm »
If anyone going to the get-together tomorrow has any or all of the following, and are willing to part with, I would greatly appreciate it if you could bring them:
-distributor hold-down clamp and bolt
-cold start injector, with the line to the fuel rail and mounting bolt
-cold start injector switch (the two-wire sensor on the top of the intake by the thermostat housing)
All parts are for the 2.8 v6.  Thanks in advance!
tyler...
« Reply #1 on: March 31, 2006, 07:43:49 pm »
Tyler, I believe I have an old plenum/manifolds lump somewhere in my shed. AFAIK it has the cold start injector and line (maybe the sensor).  I'll post as soon as I find it as it's too dark and scary now.  Dang mosquitoes are out in force already.
34FieroGT
« Reply #2 on: March 31, 2006, 08:08:43 pm »
Tell me about it!  I ended my day in the garage early today due to the mosquitos.  There were none yesterday, and today they're out in full force!
Anyways, I'm also in need of some bolts.  Specifically, I need all the bolts for the timing cover and waterpump.  Or, if someone has the specs for them, I could use that instead.
tyler...
« Reply #3 on: April 01, 2006, 09:36:48 am »
This is what I have if it's any use.
« Reply #4 on: April 01, 2006, 09:43:34 am »
I tried to edit the above without any luck.
The hardline has a bend in it and the pic makes it look kinked or damaged near the injector end.  It isn't, although there's some bumpy corrosion.
« Reply #5 on: April 01, 2006, 09:59:56 am »
Tyler if you're not on a schedule, I think we have a cold start injector  with an intact line hiding in a parts bin.  Problem is that there are (among other things) two winterized motorcycles in the way of those bins at the moment.   Roll Eyes
34FieroGT
« Reply #6 on: April 01, 2006, 11:09:19 am »
Gary:  That would be fine.  Thanks!
Don:  I am on a bit of a schedule.  I want this phase of the project finished by next weekend, and it's just these parts that are holding me up at this point.  I was sure that I had them, but after going through every single box/storage cache of fiero parts that I have, they were just nowhere to be found.
Anyone else with the distributor clamp and/or timing cover/waterpump bolts?  It would really help.  Thanks!
tyler...
« Reply #7 on: April 01, 2006, 03:59:48 pm »
I have two complete Fiero V6 top ends should still have the parts you need on them. Dan
