May 05, 2025, 01:39:48 pm
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: recent trip toward Toronto « previous next »
Author Topic: recent trip toward Toronto  (Read 1840 times)
« on: November 14, 2005, 08:01:35 am »
As soon as I fired up the '88, it just did not sound right. Got to Brockville and HAD to fill up. I figured 16.1 MPG. Now I knew something was wrong. I later went to Dan's on the return trip and got the diagnosis. 1 bad ignition module that wasn't delivering spark to two cylinders. Continued on gettting good fuel economy and made it just 5 miles short of the house and she died. A $70 tow bill !@#$%^&&* and she is bedded down. Am going to purchase a BRAND NEW module .
« Reply #1 on: November 14, 2005, 10:14:38 am »
You say it died do you mean it ran out of fuel or that something is wrong with the drive train. Dan
« Reply #2 on: November 14, 2005, 01:52:30 pm »
might want to get some of that gas out of the cylinders before you finish parking it.
Or pull the plugs and pour in some oil, turn over the motor a few times then put the plugs back.
« Reply #3 on: November 14, 2005, 02:18:59 pm »
Probably electrical, as the unit sputtered for 1 second and died in the middle of the intersection. Lots of fuel Will get a new control module anyway and hope that that is the problem.  Once it is running correctly I will fill it up with 94 octane, change to my winter tires, and put it in a garage for the winter. -----------UPDATE -- Got the module for $338 (ouch) and will put it in tonight ,weather permitting..
« Last Edit: November 16, 2005, 07:53:23 am by GoFast88 » Logged
