Hi Derek,
I am from kingston as well. If you need frontend parts I can tell you from experience order them from Odessa Auto Parts out in Odessa. I got all Moog parts at 1/3 the cost from all the others (Autopak, Napa, CDN Tire)
Also for general auto repairs I have taken mine to Robert's on Duff street they are Fiero friendly (I saw one other when mine was there) and the hourly rate is reasonable and you CAN supply your own parts.
Thank you!
Overall, it was cheaper for the mechanic in Parham to buy the front rotors, ball joints and calipers (though not by much) when compared to Napa (I refuse to shop at CT unless I absolutely need to). I see that we are getting a new automotive parts store at the RioCan Centre on Gardiners Road (can't remember the name of it).
So you have no Fiero?
I have an 85se that I have been slowly restoring. It is on the road but I'm always tinkering with something. The new parts store is PartsSource which is owned by CT.
As a side note I found the bills for some of my frontend parts for comparison;
Outer Tie rod $74.75
pair of inner tie rods $73.60 total
upper ball joint $51.75
all moog.
What killed me is I needed a rear tie rod assembly and had to by that from Condie's with a discount it was $213 ouch.
And as someone else had mentioned, because the car had not been E-TESTED I had to pass atleast once.
