May 05, 2025, 09:19:42 am
Ottawa Fiero Club Forum  |  Buy/Sell/Trade  |  Parts  |  Topic: HELP, Vac. Line « previous next »
Author Topic: HELP, Vac. Line  (Read 2352 times)
Rob
« on: July 21, 2004, 08:42:52 pm »
Hey
It would seem that i have lost my vacume line that goes to my fuel pressure regulator.. How I lost It I have no clue as every thing else seems to be in order, just need the vac line to button it up and start er up again. I have some vacume lines from my 2.5l ones even long enough, but has the wrong end on it, so If I was to get some sort of connector  from canadian tire do you think it will work? are all vac lines essentialy the same.. Im sure it would probley work, I just dont know if the diameter of the line makes a lot of difference...
Thanks; Rob
« Reply #1 on: July 26, 2004, 12:18:25 pm »
Did someone say vacuum lines, I know what you could do with those.  Can anyone say clean carpets.
I’m just kidding.  Basically the vacuum line diameter is just a guideline.  There should be no problem using a connector.
« Reply #2 on: July 26, 2004, 07:11:51 pm »
I have a stripped top end off a Fiero 2.8 in a box, your welcome to come see if it still has what you need. Dan
Rob
« Reply #3 on: July 27, 2004, 08:54:53 pm »
Thanks guys, I did figure out that I hadent lost it, I just didnt realize that it was still attached.
Later; Rob
