May 06, 2025, 06:42:14 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: New Memeber « previous next »
Author Topic: New Memeber  (Read 2533 times)
86Fiero2M6
« on: July 05, 2004, 06:34:25 pm »
Hey guys and gals!
My names Len and I'm from Welland,  about 20 minutes outside of Niagara Falls way down here in Southern Ontario!
I'm the proud owner of a 1986 Pontiac Fiero 2M6.  Right now its out of comission as I am replacing the horribly worn valve seals and doing a little fibreglass work on the spoiler pedestals!
This is a picture from last spring
This is the other day
I've been lurking around the board for a few days and it seems like  really great place!  I hope to make it out to a couple of meets at least this year once the car is done.
So, anybody else down here in Southern Ontario on the board?!
Len
« Reply #1 on: July 05, 2004, 07:53:19 pm »
Welcome to the group, most members are in the Ottawa area. Myself I live near Belleville but I do not know of any from as far away as you or at least not in that direction. Most meetings consist of falling over attractive waitresses while discusing our cars. Dan
« Reply #2 on: July 06, 2004, 05:26:59 pm »
Welcome to the board!  Take Dan's note with a grain of salt.  Being from Belleville 'attractive' is not what you may think.
You might check out the GTA board as well.  They are not nearly as active or witty as we are................  Cool
« Reply #3 on: July 07, 2004, 10:37:15 am »
Welcome to the board.  We enjoy the typings of all those that have something intelligent to say or write.
« Reply #4 on: July 07, 2004, 12:07:20 pm »
This coming from someone who not long ago was rambling on about using vacuum leaks to clean carpets???   Grin
« Reply #5 on: July 07, 2004, 04:02:09 pm »
Don't get me started, because that is a really good idea.  Turning a problem into a useful item.
Besides I didn't say everything had to be intelligent, just something.
« Last Edit: July 07, 2004, 04:03:43 pm by aaron88 » Logged
« Reply #6 on: July 07, 2004, 07:31:08 pm »
Whoo hoo if inteligence is not required than I can stay. Dan
« Reply #7 on: July 08, 2004, 07:32:44 am »
I think that I am up for that.
« Reply #8 on: July 08, 2004, 10:05:52 am »
Come to think of it cat hair is totally organic, and fine enough that it should burn up without a trace and not do any harm to an engine.  If I used engine vacuum to clean the carpets, all the cat hair in our place would get burnt up and blown out the tailpipe.  I wouldn't have to empty the cannister on the central anywhere near as often!
I can't believe I just said that.
