May 05, 2025, 06:10:03 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: Does Someone Have A Lathe I Can Use??? « previous next »
Author Topic: Does Someone Have A Lathe I Can Use???  (Read 1951 times)
BootMachine
« on: December 02, 2003, 11:52:34 am »
I'm building a motor for my car and I wanna shave a little meat off the pullys......just to see what happens!
Is there someone out there who will lend me the use of their lathe for an hour or so?
« Reply #1 on: December 02, 2003, 05:24:12 pm »
There is a lathe at my work but a few years ago someone smashed into it with something really heavy, so now it doesn’t turn about a good fixed point.  It wobbles a good 25 thou or so.  Therefore it’s no good for taking off small amounts of material or for refinishing material.
I don’t recommend you use it for your application.
But I should have a lathe of my own in a year or so.  You’re welcome to use that one
BootMachine
« Reply #2 on: December 03, 2003, 11:41:32 am »
What did they hit it with???
A TANK!
That lathe is the biggest one I have ever seen...well..in real life anyway...
As if it does not work properly...thats sad....so expensive too! That lathe is SOOO nice!
Just did a little calculation....because I use metric...its only off by less then 1/2 a MM. Can I try it out anyway and see what happens?
I mean....by buddy did it with a vice and a grinder and his is OK...so this cant be that bad !!!  Grin
« Reply #3 on: December 03, 2003, 02:51:18 pm »
It really depends on what operation you want to do.  Some will be beter than others.
It's actually off by more than a half mm but not more than 1mm.
I'll be at the shop on Tuesday night.
BootMachine
« Reply #4 on: December 05, 2003, 02:44:53 pm »
1mm is ok too!
If it flies off the engine and smashes into a million pieces I have another one I can use anyway!
I would VERY MUCH appreciate your assistance with this small project....and also I want another look around your massive shop!!!  Grin
Sorry I didnt get back on here earlier....when is a good time for you?
