May 06, 2025, 02:30:19 am
Ottawa Fiero Club Forum  |  Buy/Sell/Trade  |  Parts  |  Topic: f.yi., this is still available! « previous next »
Author Topic: f.yi., this is still available!  (Read 1708 times)
A.K.A
« on: October 20, 2003, 10:06:25 am »
Ok guys. Winter is comming and not all of us are rich mofo's who can afford winter beaters so here it is.
OUR VERY OWN WINTER SERVICE PACKAGE!
YOU GET:
1) Tires rotated -or- winter tires installed. You gotta have the winters on rims already but we will install them and if you worry we will use factory specs on the lugs and a torque wrench!
2) Change Oil and Filter. We will use a low weight oil for winter startup using ONLY Factory recommended oil (Castrol/ Valvoline). We will not put NEW GOLD in your engine. If you want a full sythentic oil we can do that too for only the extra cost of the oil. We use FRAM DOUBLE GUARD FILTERS also.
3) Change Tranni Fluid. We will change the fluid on your manual transmission using factory recommended CASTROL 5W30. Torque wrench on the drain and fill plugs too...no worries.
4) Coolant Flush. Drain out the old stuff and fill it with new. We will use only PRESTONE COOLANT in your rads.
5) Condition Seals. All the seals on the doors, sunroof, hood and trunk will be cleaned with hot soapy water, dried and softened with ACRYSOL SEAL CONDITIONER.
6) Front/Rear Suspension and Brake Inspection. FREE...we know what to look for so when the wheels come off for rotating we will take a look where the sun dont shine and look for cracked boots, seals, leaking oil and bent/worn parts!
7) Window Runners Lubed. We will spray DRY GRAPHITE in the window runners and wipe clean for that buttery smooth up and down action.
Cool !!!! UNDER COAT YOUR CAR !!!! We provide a number of different products to choose from but this package includes RUST NOX. Its a complete luquid penetrating oil that will absorb into the vital metal components of your car (minus the exhaust...that would stink) proventing rust from forming (Used by top end dealerships....we know!!!). Any additional coating products can be discussed prior to service date.
This will take us an afternoon to accomplish and you can watch us work if you like...no bullshit...we do what we say we will do!!!
Here is the price....$275.00 for everything....materials included!
All we need are Vehicle specs and a date!
Each service may require vehicle downtime of 4 hours (depending on size, wieght and overall condition of vehicle)
Let me know!
(via pm or marc_t_Guay@hotmail.com)
« Last Edit: October 20, 2003, 10:09:02 am by a.k.a » Logged
