May 06, 2025, 12:36:26 am
Ottawa Fiero Club Forum  |  Buy/Sell/Trade  |  Parts  |  Topic: Seat back skin « previous next »
Author Topic: Seat back skin  (Read 2783 times)
« on: September 27, 2003, 05:04:59 pm »
While cleaning up  Grin I came across a very nice seat back cover.  It is solid dark gray and from a speaker seat (not sure 84 or 85)  There are no crests or stripes, just all gray. Fabric front and leatherette back.
Nice for someone who has a ripped bolster.
A.K.A
« Reply #1 on: September 28, 2003, 11:03:24 am »
how much??  Grin
« Reply #2 on: September 28, 2003, 11:21:46 am »
Free for you.....troublemaker  Grin
A.K.A
« Reply #3 on: September 28, 2003, 11:23:51 am »
EXCELLENT!!!!!!!!
A.K.A
« Reply #4 on: September 29, 2003, 09:04:19 am »
a huge thank you going out to gary/FieroBUZZ
man those are in mint shape  Shocked
although, I have yet to install them, a large thank you is being extended!!!!!
 Grin Grin Grin Grin
p.s. that cd gave me some ideas...... Cheesy
A.K.A
« Reply #5 on: September 29, 2003, 05:45:01 pm »
ok, so I now have the skin....how does one put it on???  Huh
do you have to remove the seat? and what are those bars that run the length of the seat back called??
Thanx
Marc
« Reply #6 on: September 29, 2003, 06:24:44 pm »
It's been a long time since I had one apart.
I would remove the seat and also remove the back for easier access, personally.  You need a hog ring pliers and hog rings to do the job.  I have that stuff here somewhere.  Huh  You'd have to see my garage to get that one.
Unzip the cover and you'll see that the ends are tacked to the seat with hog rings.  Much easier to cut them and get them out.  The long bars also have hog rings and they loop over a wire in the seat back.  They keep the cushion folded into the groove beside the bolster.
As you remove anything attached, pull the cover up by turning it inside out.  There'll be more rings at the wire mentioned above  (just under the head rest).  Once you get going it's pretty easy to see how it's put together.
If your bolster cushion is badly mangled (the wire frame tends to poke thru) then you can either get another or patch with foam and duct tape it together to get the right shape.  It will be under the cover.
