May 04, 2025, 11:03:24 pm
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: Distributor Install « previous next »
Author Topic: Distributor Install  (Read 2623 times)
lsixtyseven
« on: September 19, 2003, 11:29:07 pm »
I want to install my distributor on my 2.8, and all the marks I made have disappeared. I'm at tdc #1 cylinder on compression. From pictures I've seen it looks like the #1 spark plug wire position on the cap is about 3 o'clock. The distributor looks like the module is about 8 o'clock. Can anyone set me straight. Smiley
« Reply #1 on: September 20, 2003, 09:38:06 am »
Pretty close.  I have closer to a 7 o'clock ignition module, and a 3:30 #1 wire.
If you set it up somewhere between what you have now, and what I have above, that should be enough to get her started.  Then put her in "field service mode" and set it for real with a timing light.
« Reply #2 on: September 20, 2003, 09:47:15 am »
Here's a pic, fresh from the driveway.  Smiley
P.s. Chris, any chance on changing the "maximum execution time" allowed for a posting operation to something greater than 30 seconds?  It makes posting images via dial-up virtually impossible.
« Reply #3 on: September 20, 2003, 03:33:20 pm »
I am not to sure but I will see what I can do.
Gizmo
« Reply #4 on: September 20, 2003, 09:08:24 pm »
Yeah I've noticed that the gallery is somewhat looped, if someone can find something other than what we have now that would be great....chris did you find anything?
lsixtyseven
« Reply #5 on: September 20, 2003, 09:22:28 pm »
Thanks Don for the info, really helpful. Smiley
