April 30, 2025, 06:00:14 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: Throttle cable heat shielding « previous next »
Author Topic: Throttle cable heat shielding  (Read 2756 times)
tweeder
« on: August 07, 2012, 01:25:07 am »
What all are you shielding your cables with? My exhaust is wrapped. The cable had a plastic tube over it, then what looks like a length of 1/4" thick hose and a heat shielding blanket. With all that, I still melted the inner liner. I'm waiting on a replacement cable and don't want it it happen again.
« Reply #1 on: August 10, 2012, 10:25:17 pm »
The cable is just getting too close to the exhaust.  Use something to hold it closer to the fire-wall.
Also I find that exhaust wrap isn't enough protection.  You really should use a double walled exhaust header and cross over/down tube.
tweeder
« Reply #2 on: August 11, 2012, 11:15:48 am »
There wasn't enough room to move the cable over top of the engine.  I replaced it with a new one that for some reason is 1/2" shorter.  So I had to move the bracket up more so the engine wouldn't idle at 2000rpms.  In doing this I left enough slack to be able to have the cable sit over top of the throttle body.
