May 02, 2025, 12:48:12 am
Rear coil overs
Topic: Rear coil overs (Read 3493 times)
Rear coil overs
August 06, 2009, 10:15:06 am »
My new toy is getting all new poly bushings and also needs rear struts, my question is are coil overs worth all the extra cost and trouble. I am not looking for major handling improvements but do like the idae of being able to adjust the ride height for different types of driving.
On my last car I just used stock replacement struts to replace the 20 some year old ones and they worked nice with a nice smooth ride but I am thinking of going a little better this time around. The Fiero store has some decent deals on struts and with the dollar being in decent shape it is a good time for buying from the states so I am alos considering going with a set of KYB's and possible 1 inch drop springs. Anny opinions will be appreciated. Dan
Re: Rear coil overs
August 06, 2009, 03:58:25 pm »
Do you have any plans for messing with wider tires in the rear?
Switching to coil-overs will open the door to more combinations of width & offset fitting in there without that big ol' OEM spring seat getting in the way.
Re: Rear coil overs
August 06, 2009, 04:20:34 pm »
Well the 235/55-16's I have right now seem to have traction issues so I would end up going with a little wider if I go with coil overs.
Right now you can not get your finger between the top of the tire and the strut so that is as wide as I can go right now.
I see west coats Fieros sells a kit for $220 that goes on stock struts that can have the perched shaved down a little for clearance.
Biggest problem is where to buy the parts to build a decent set of coil overs with out dealing with places like WCF's. Dan
falcon_ca
Re: Rear coil overs
August 06, 2009, 10:52:13 pm »
I built my adjustable coil-over using Gabriel struts, that I "skinned" and a kit for 89-93 Ford Mustang front adjustable coil-over (7 inches sleeve). I used 12 inches 250 pounds springs. The strut heads and mounts are original 88 Fiero parts. I did not used the bearing and small washer, they are needed when install in front.
I have 1 inch lowering ball join in the front and adjustable Chapman rear strut.
The car is a modified Formula.
Restoration Formula
4.9 Ongoing project
Madscanner
Re: Rear coil overs
October 27, 2009, 05:53:31 am »
How is the ride?
I ask, because I put 375 lb springs on the back of mine when I did my conversion.
'88 Formula
'85 SE 2M6
'93 Eunos Roadster
'01 Fiesta Zetec S (for when I need more than 2 seats!)
'06 Vauxhall Astra (for when the Fiesta gets sold)
'01 Yamaha Dragstar
Re: Rear coil overs
October 27, 2009, 06:36:16 am »
I'm debating going with coil overs as well. I'm thinking of Auto Xing mine so I'm looking at doing a major handling upgrade.
falcon_ca
Re: Rear coil overs
October 27, 2009, 05:51:41 pm »
The ride is a little bit harder but I love it.
I have poly all around so the car drives like a go-cart.
Restoration Formula
4.9 Ongoing project
cowans
I'm a llama!
Re: Rear coil overs
October 27, 2009, 10:07:43 pm »
250lb springs in the rear?
I don't know your car but have you an engine in there? Mine, albeit a pig of an SBC, is wearing 425lb rear, 250lb up front! Yes, it's a little tight, but makes for a gokart on steroids! With the car so wide.... there is NO lean!
best,
falcon_ca
Re: Rear coil overs
October 28, 2009, 08:33:37 pm »
Quote from: cowans on October 27, 2009, 10:07:43 pm
best,
Engine is the stock 2.8 and I have a 4.9 in construction.
Restoration Formula
4.9 Ongoing project
Rear coil overs
