You know, we tend to look at Dan as some kind of genious, throwing together swap after swap. They say the wiring is too difficult to do at home. Well, I figure I can do it too. After all, I'm much better looking than Dan.
Plug in the various wires to the motor, and throw the ball of wire (loom) over the top to see where it lands. I have the wiring diagrams and the motor ran before it came out...right? First wire, ID it, maf sensor ground, pull out a bunch of wire, cut it off and label it ground. Any fool can ground a wire later. Second wire, maf sensor, 12 v, wow! is this cool or what. I can get power later too, so cut and label it. Next, maf sensor, to ecm plug. Okay, check my notes and guess what? No frickin' maf wire listed. Okay that's an oddity, so we'll cut it off and label it 'WTF' for obvious reasons.
After a while playing, I have several wires needing power or 6 volt reference, a few grounds, a couple to the ecm plugs and a dozen labelled "WTF" This is going great!
Geez, I hope the boy wonder doesn't have a stroke when he gets a look at this. Just to check my work, mind you.
