May 03, 2025, 07:38:20 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: oil pressure sending unit « previous next »
Author Topic: oil pressure sending unit  (Read 1750 times)
ballplayer
« on: December 09, 2005, 07:35:27 pm »
where is the oil pressure sending unit on a 1984 fiero
« Reply #1 on: December 12, 2005, 10:16:14 am »
IIRC it's not so much a "sending unit" as it is a switch on the 84 which closes when the pressure drops below a minimum amount.  You'll find it screwed in to a port on the block, below the intake manifold and to the right of the distributor.
