May 05, 2025, 02:00:56 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: Amazing the difference a functioning cat makes « previous next »
Author Topic: Amazing the difference a functioning cat makes  (Read 2955 times)
« on: October 22, 2003, 05:41:57 pm »
Before:
Limit
[/b]
Reading
[/b]
HC ppm
[/b]
106
82
CO %
[/b]
0.59
0.68
[/color]
NO ppm
[/b]
1164
1445
[/color]
After:
Limit
[/b]
Reading
[/b]
HC ppm
[/b]
106
20
CO %
[/b]
0.59
0.02
NO ppm
[/b]
1164
695
Phew.  Now I can put her in to hibernation, before the M.T.O. starts flinging salt everywhere...  Smiley
BootMachine
« Reply #1 on: October 23, 2003, 04:10:48 pm »
WOW...big diff!
WillEV
« Reply #2 on: October 23, 2003, 04:54:30 pm »
Was that a hight flow cat you used?
« Reply #3 on: October 24, 2003, 10:58:43 am »
Yup.  It's the one which Rodney Dickman sells.  (go to the "Engine" tab of his page, and look for Replacement Catalytic Converter.
Including shipping & whatnot it worked out to about the same price as a high-flow stainless steel cat from local sources, plus extension pipes, plus hassle.  A 20 minute install with a saws-all or other handy cutting tool to remove the old cat.
The only thing I'm not entirely pleased with as far as Rodney's cat goes, is that the s/s clamps he includes.  The extensions which mate up to the OEM exhaust are 2 1/8", but the clamps he sends are 2 1/4".  Then again just try and find a 2 1/8" stainless steel muffler clamp.   Roll Eyes  I ended up spending another $4 at CTC for a pair of proper size mild steel clamps.
« Reply #4 on: October 24, 2003, 05:08:29 pm »
I am glad your car passed e-test but I still feel my idea of a 3800SC swap would of been easier. Changing complete set up is much easier than changing one small piece. How do you like that logic (works for me). Dan
« Reply #5 on: October 24, 2003, 05:33:14 pm »
I disagree Dan
I think you went the hard way, because you used the auto that came with your motor.  I think you generated all sorts of unnecessary electrical troubleshooting requirements.
Besides with the northstar the cat isn’t even required (because I don’t feel like making it fit) and what could be easier than not putting the cat on at all.
« Reply #6 on: October 27, 2003, 01:49:27 pm »
"Complete" setup?  Oh puh-lease!  Unless something has changed recently, you're still missing 1 pedal in the cockpit.   Tongue
Show me a tweaked L67 mated up to a 4-spd Muncie & 3.32 diff, then we'll talk.    Roll Eyes
