General => Project Work Logs => Topic started by: can machine on September 14, 2016, 09:28:40 pm
Title: 3800 Swap
Post by: can machine on September 14, 2016, 09:28:40 pm
Well I've been able to work on my swap a bit in the last month and I finally got most of the engine done. Just mocked up the belt pulleys and low mount engine set up I got from Fierorog.
(http://i.imgur.com/rSwb0h5h.jpg)
Still got a few things to paint on the engine yet, just wanted to make sure everything fit.
Title: Re: 3800 Swap
Post by: aaron88 on September 17, 2016, 03:17:16 pm
Looks nice and clean.
Post by: Dan on September 17, 2016, 06:57:37 pm
looking good but don't forget to swap valve covers from side to side to make oil changes a lot easier after the swap is done
Post by: can machine on September 17, 2016, 10:10:32 pm
Yeah just swapped the valve cover today actually.  :)
Post by: Dan on September 18, 2016, 11:17:20 am
hope you installed new gaskets and also replaced the lower intake gaskets with the newer aluminum ones as the engines like to leak fluids
Post by: can machine on September 18, 2016, 09:01:06 pm
Yeah I bought the complete gasket kit from top to bottom. The only thing I didn't do is pull the bottom end apart ie: bearings, rings, pistons.
