Buy/Sell/Trade => Parts => Topic started by: aaron88 on May 09, 2006, 03:01:25 pm
Title: adjustable brake proportioning valve
Post by: aaron88 on May 09, 2006, 03:01:25 pm
I designed an add-on to make the proportioning part of the combination valve adjustable.
I’m wondering how many people would be interested in one.  It’s fairly simple design so it shouldn’t cost much to have made.  I'm re-using the spring and rubber seals, so I’m thinking somewhere around $50.  I’ll have a better idea after I test the prototype to see if it needs a re-design.
I’m not going to eat the cost of having them made since I’m not going to mark up the price, so don’t answer unless you are absolutely sure of your answer.
If all goes well I may make them available for general sale.
Title: Re: adjustable brake proportioning valve
Post by: dguy on May 10, 2006, 08:42:44 am
What will be adjustable--the "delay" in rear brake application when one mashes the pedal quickly, the overall front/rear balance, or both?
Post by: aaron88 on May 11, 2006, 12:38:33 am
The adjustability is for the front to rear bias.  Assuming that you will be increasing the rear bias the delay would be reduced (slightly) to the rear brakes (increasing the controllability while braking into corners).  This used in conjunction with a 2 lb residual brake pressure valve (Willwood) would be ideal for autocross and overall control.
However I don't personally plan on using a residual pressure valve.
UPDATE  xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Reducing the delay timing on the rear brakes, which is about a tenth of a second due to the extra passages and length of line is much too complicated to achieve inside the desired sail price.  So that issue has not been addressed.
Alternately you could use a residual pressure valve in line with the rear line after the proportioning valve.  This would decrease the rear brake piston travel, thereby achieving the desired result.
Post by: 34FieroGT on May 11, 2006, 07:53:57 am
Sounds good!  I would be interested in one.
Post by: dguy on May 11, 2006, 08:22:46 am
What ^^^ said.
Post by: aaron88 on May 15, 2006, 10:03:36 am
I suppose this thread should be in mods?
Post by: aaron88 on May 19, 2006, 02:30:12 pm
Here is a preview.
Post by: aaron88 on June 07, 2006, 01:48:13 am
I can't seem to find that motor trend video that showed all the model years and more importantly the stoping distance for the 88 model. 128' I think and from some speed, I can't remember.
anyone?...anyone?....Bueller?...Bueller?
Post by: aaron88 on June 11, 2006, 09:27:23 pm
Bueller?.....Bueller?....Bueller?
Post by: aaron88 on June 15, 2006, 11:53:06 pm
update
Tested and working!
Constructing second prototype.
88 and pre-88 are different springs and spring rates.
Post by: dguy on June 16, 2006, 09:54:45 am
update
But of course!
BTW I think we have two or three of the pre-88 combination valves if you need one for any reason.
Post by: aaron88 on June 16, 2006, 09:51:36 pm
Couldn't hurt to check them for tolerancing.  No rush though.
Post by: dguy on July 03, 2006, 02:54:02 pm
Managed to dig up three of them, each with a different casting number FWIW.
Pick a time & place....
Post by: aaron88 on July 03, 2006, 10:30:04 pm
Sweet...
Probably lot numbers (casting run numbers) so they know which ones to chuck if there's a bad run.
I'm in the middle of a move right now, I'll be at it for just over a week to come (painting and all that other stuff).  But I do think I can manage to get over to see Kitten at work this week if that's not too much to ask?
Post by: dguy on July 04, 2006, 05:40:40 am
No problem at all.  She has them with her as of this morning.
Post by: aaron88 on July 25, 2006, 02:42:53 pm
Sorry about the delay!  I have been a little more busy than I had originally anticipated.
Post by: dguy on July 25, 2006, 02:51:58 pm
No prob, they're still waiting for you.  Just give us a day's warning before you want to pick them up.
They're in the back o f the Beetle at the moment and ifyou happen to drop by on a day we take the bikes to work, they'll be where you are not.  :)
Post by: dguy on February 12, 2007, 08:02:09 am
Poke poke poke...  Aaron, how are you making out with these things?
We're probably going to install the "Zettner" brakes on the 84 some time this season; would be nice to be able to fine-tune the bias.
Post by: aaron88 on February 13, 2007, 11:28:21 pm
Everything was done last year.  New prototype installed and working fantastic.
Unfortunately I haven't had any access to tools to make any more.
I might be able to work something out with a friend of mine if need be.  In my opinion it works so well that everyone with a Fiero shold get one even just to adjust the old weakened factory spring.
Best value brake upgrade for anyone that knows what they are doing.
Most dangerous brake upgrade for all those that don't know what they are doing (still worth it though).
Post by: FieroBUZZ on February 14, 2007, 06:34:54 am
My favourite category.   ;)
Post by: aaron88 on August 03, 2007, 11:12:16 pm
I will be making 6 adapters a week from now.  If someone want's one, please measure the nut on the rear of your combination valve (19mm or 21mm?).
Also, I would like to test the operation of this valve on a car (84-87) that has a large front brake upgrade combined with stock rear brakes and rotors.  The voluteer must be in resonable driving range of me, have time for and be willing to allow testing.  This volunteer will also receive a free valve (go figure).
Post by: 87GT on August 04, 2007, 10:23:25 am
Aaron,
I'll take one, (19 mm).
Let me know when available.
Gord
Post by: dguy on August 04, 2007, 08:06:49 pm
We're in for two.  I'll measure the valves tomorrow and let you know the nut sizes.
I'll quite happily be your guinea pig, assuming that no one else has stepped forward yet.
Post by: aaron88 on August 06, 2007, 10:22:21 am
Done.
I'll be gone till latter in the week.
P.S. By the way everyone.  The 19mm nut allows adjustment of the rear brakes to higher pressures.  More on that latter.
Post by: dguy on August 06, 2007, 05:24:06 pm
One of each, please.  Both cars currently have valves with 21mm nuts, but one of our spares is a 19mm.  Give me a shout when you're back & ready to test, and I'm all yours.
Post by: 34FieroGT on August 06, 2007, 08:18:07 pm
Put me down for one as well.  I'll have to get you the nut size later though...
Post by: aaron88 on August 14, 2007, 10:42:46 am
If anyone is wondering what the delay is...I'm waiting for the o-rings to come in.  Because of the fluid in the braking system rubber o-rings can't be used, and there seems to be a delay on my EPDM order.
Thanks for waiting.
Post by: aaron88 on August 23, 2007, 02:50:05 pm
O-rings are in!
Post by: dguy on August 24, 2007, 10:20:58 am
Your lab rat is ready when you are.   ;)
Post by: aaron88 on January 18, 2013, 01:18:52 pm
I have posted an installation video on youtube.
http://www.youtube.com/watch?v=HdkKM9o9b9k
Regards,
