Title: '85 2.8 starter and alternator f/s Post by: fiero308 on August 19, 2003, 07:00:57 pm hi all
I am putting a bunch of stuff up on ebay and thought I would see first if anyone locally wants or needs a starter or alternator for a 2.8. I am doing that engine swap and so don't need them, and they worked fine for me. I am asking $25 each and they would make exc spares I think. The starter in particular seems to be a trouble item so a spare may not be a bad idea. Let me know soonest!!! thanks. Tiberio and Tyler; could you send me an email when you get a chance? (trying to get some stuff out of the garage.......... ;) ) thx!! ;D Title: Re:'85 2.8 starter and alternator f/s Post by: fiero308 on August 20, 2003, 11:35:09 am Update:
the starter is sold; but I am trying to determine if the alternator is from an A/C car ore not. (my 2.8 is a swap-in to replace a 4 cyl) If anyone knows how to tell or what to look for could you let me know pls? I could post a pic if that might tell the story. thx! :) Title: Re:'85 2.8 starter and alternator f/s Post by: fiero308 on August 20, 2003, 01:42:17 pm looks like it is a 63 Amp alternator; that would be the NON a/c unit I am sure; I think the A/C unit would be 110 or something considerably higher. I am also guessing a bit but see the pic and I believe that 63 is a standard output for them. The last few characters in the top line should tell the story.
If questions pls email direct or here. Thanks Worked fine on my 2.8. .... ;D Title: Re: '85 2.8 starter and alternator f/s Post by: stroker on October 05, 2004, 09:30:27 pm with a/c you will read 78 instead of 63 so that is 78 amps
marc the stroker. Title: Re: '85 2.8 starter and alternator f/s Post by: stroker on October 08, 2004, 10:20:48 pm i was wrong with the 78 amp i checked today and it is 94 amps witch lester catalogue system calls a 7294 for 84-87,it's the 12si series
and for 88 you get an 105 amp witch is the newer batch called the cs series with the newer style connector. marc the stroker. Title: Re: '85 2.8 starter and alternator f/s Post by: fiero308 on October 21, 2004, 05:11:28 pm well the alternator is still available for anyone who needs one; let me know.
I have a bunch of misc other stuff available; rear coil 'cooling' fan and pipes/ducts; radiator; I guess I will have to go thru it all and list it properly. ;D gp |
