Title: 4 speed shifter Post by: 2ML67 on September 16, 2006, 02:20:44 pm Was fooling around with an 84 Fiero 4 speed shifter, sort of redesigned it to work with a shifter knob off a 70's Trans Am. Was going to use it before I decided to just get a 5 speed instead, now I no longer need it so any one in need of a 4 speed shifter like this. Will get a photo up later. Dan
Title: Re: 4 speed shifter Post by: dguy on September 16, 2006, 03:19:55 pm If you're talking about that little short one you showed me last weekend, I'm pretty sure I can find a home for it. :)
Title: Re: 4 speed shifter Post by: FieroBUZZ on September 16, 2006, 03:25:41 pm Anyone who has a Fiero shifter and wants to shorten it should do this.............
Grind (finally) the welds off the shifter shaft. Throw away the fat shifter that few knobs fit. Cut a suitable shifter off at your local stablishment and bend to suit and weld back on the Fiero unit. Voila! Aftermarket knobs galore. Title: Re: 4 speed shifter Post by: 2ML67 on September 16, 2006, 06:46:44 pm I would listen to Gary if there is one thing he knows about its knobs. Yes Don its the one I showed you will set it aside till next time I see you. Dan
Title: Re: 4 speed shifter Post by: dguy on September 16, 2006, 09:03:03 pm I would listen to Gary if there is one thing he knows about its knobs. Yes Don its the one I showed you will set it aside till next time I see you. Dan Thanks! O0 I switched the shifter in the '85 to the shorter '84 shaft a while back, but that one's still too long for my liking. |
