Title: Lean puzzle Post by: dguy on June 25, 2004, 08:59:38 am Kitten's car likes to play with my mind. ::)
When driven at a sustained RPM of about 3,250 or higher, it will occasionally whine about an excessive lean condition being picked up by the O2 sensor. Reducing speed to 3,000rpm (or less)always remedys the situation within a few seconds. ...and it's totally intermittent. Sometimes she'll complain within a few seconds of running that fast, other times she'll comfortably cruise along without missing a beat. My first thought was an intermittent open circuit or corroded connections between the O2 sensor & the ECU. Strike 1. Next was a tired fuel pump which couldn't deliver the volume needed under load & high RPM. Strike 2. In progress, is a hunt for vacuum leaks. Anyone else have any suggestions before this repeated bashing of my head against solid objects causes permanent scarring? Title: Re: Lean puzzle Post by: 2ML67 on June 25, 2004, 09:38:24 am Had a similar problem once was vacuum line at cruise control canister, also replace fuel filter they can clog up pretty good. I still say best way to fix is to swap in a bigger engine. HEE HEE Dan
Title: Re: Lean puzzle Post by: Kitten on June 25, 2004, 10:04:09 am I still say best way to fix is to swap in a bigger engine. HEE HEE Dan no no no no no.... I'm not ready to do that yet :P Title: Re: Lean puzzle Post by: dguy on June 25, 2004, 11:22:53 am Had a similar problem once was vacuum line at cruise control canister, also replace fuel filter they can clog up pretty good. I still say best way to fix is to swap in a bigger engine. HEE HEE Dan D'oh ... nice catch on the fuel filter. Thanks. As for a bigger engine... eventually she'll get one. But mine first. ;D Title: Re: Lean puzzle Post by: GoFast85 on June 25, 2004, 12:04:05 pm Had a strange experience last week. About 100 meters from my home I heard a wining noise coming from the enging compartment. Supercharger acting up or what, I thought?. Parked the car and the engine idle went up and down and the engine died. Did I forget to check the oil, or not notice the engine falling out?? Started it back up about and hour later and got about 1100 meters and it died. Cruised into the gas station that was handy just in case I had to tow it back home. Looked a the gas guage and was over 1/4. Decided to put $10 in just in case. Car ran like a charm after I put fuel into it. Moral of the story?? Check the EASY things out first!!
Title: Re: Lean puzzle Post by: 2ML67 on June 25, 2004, 08:19:24 pm Those engines shut them selves down when fuel pressure is too low due to either bad parts or low fuel. Does save the engine though when something goes wrong. Dan
Title: Re: Lean puzzle Post by: GoFast85 on June 28, 2004, 07:29:51 am when something goes wrong Does running out of fuel constitute operator error ;DTitle: Re: Lean puzzle Post by: 2ML67 on June 28, 2004, 09:16:27 am I think it falls into the either the oops or the oh crap categorie. Dan
Title: Re: Lean puzzle Post by: FieroDough on June 28, 2004, 10:00:28 pm check for the EGR stuck open. you can be taking in excessive exaust gas at higher RPM.
Cheers! Eric Title: Re: Lean puzzle Post by: Kitten on June 29, 2004, 08:01:41 am Well we replaced the fuel filter and the check engine light hasn't given us the lean warning since.... and it's also not complaining as much when it hasn't warmed up enough either, which is a nice side effect :)
Title: Re: Lean puzzle Post by: aaron88 on June 29, 2004, 10:58:21 am Vacuum leak? Haven’t you learned yet.
Step one: attach hose Step two: clean carpets Step three: enjoy the free advice Aaron . Title: Re: Lean puzzle Post by: dguy on June 29, 2004, 11:15:25 am Vacuum leak? Haven’t you learned yet. Step one: attach hose Step two: clean carpets Step three: enjoy the free advice You need help. ;D |
