Title: needed ASAP! Post by: FieroDough on February 02, 2004, 08:03:59 am Lowering spreings for my GT (86)
Complete poly bushing set, all but the cradle (already took care of that) need a new isuzu tranny. (no, it's not broke, but i want a second one!) Shift cables, 85+ isuzu 5spd master and slave cyl. Clutch hose from front to back, in good shape! and.. that's about it for now. :) Cheers! Title: Re:needed ASAP! Post by: GoFast85 on February 03, 2004, 01:00:06 pm isuzu at:
http://www.fiero.nl/forum/Forum4/HTML/018332.html Title: Re:needed ASAP! Post by: FieroDough on February 03, 2004, 01:09:34 pm Portland, Or is a littel far. :P
Title: Re:needed ASAP! Post by: cowans on February 06, 2004, 12:52:24 pm Eric, contact 'REBEL' as told to me by Gary... he has one.
Rebel (Marcel) has an 85 parter with an Isuzu. I don't know what it's like or what his plans for it are...... His tel#= work 613-257-7551 or fax 613-257-7552 Sandy or you could try Conroy's on 10th line. I picked up an 89 Cavalier Isuzu for $50. He's apparently closed for winter, but, if you leave a note at the door, they will supposively call you back. With a Cavalier you just switch out the top plate(4 bolts) and add the Fiero cable bracket! I would change the seals at the same time, and make sure you replace then with needle bearing seals! Sandy Oh! I have a spare master and slave....$25. each! Title: Re:needed ASAP! Post by: a.k.a on February 13, 2004, 01:43:16 pm f.y.i ( and in lieu of a pm ) I can get eibach's ( i think it's a .8 inch drop...) for the 84-87 boys for around 350 and intrax for slightly more
the price can be less if you want to make up a group buy! :) |
