General => General Chat => Topic started by: WillEV on May 02, 2005, 11:56:41 pm
Title: code 33
Post by: WillEV on May 02, 2005, 11:56:41 pm
ok I haven't ran my car for about 2yrs, when I put it away then the idel was slightly high. Well I put a new battery in it today and it was reving all the way up to 4000 rm. :(
I checked the computer and it gave me a code 33 - MAP sensor or a vacum leak. I'm thinking vacum leak rather than the sensor.
What do you guys think, has anyone have this problem before?
Will
Title: Re: code 33
Post by: aaron88 on May 03, 2005, 09:26:10 am
Even if you do have a problem with your map sensor you still also have a vacuum leak.  I'm not sure how else you could have an idle that high?  Also check the positioning of the throttle plate and IAC (still a vacumm issue).
Title: Re: code 33
Post by: Joe Fieroshop on May 03, 2005, 11:15:47 am
Will, do you have a V6? if so check the EGR pipe, sometimes they'll cause a high rev. vacum leak. One way to find out is by spraying cab. cleaner along the tube, especially at each end ( plenum base and EGR addap. base)
Hope I could have been some help to you, good luck.
Joe
Title: Re: code 33
Post by: dguy on May 04, 2005, 12:11:25 pm
Kill the vacuum leak, then worry about the MAP sensor if it's still blinking that pretty orange light at you.
Wouldn't surprise me if you had a failing vacuum line when you put the car away, and dry rot has done the rest of the work over the last two years of storage.
