Title: Mustange tri-light break lights Post by: FIERO-JOE on September 30, 2016, 07:48:58 am hey all I'm about to put in the tri-light breaking lights and turn lights, seen on the newer mustangs..
our fiero's have the same 3 light systems.. and well.. I can only assume the wiring systems are the same.. wish me luck.. Title: Re: Mustange tri-light break lights Post by: can machine on October 01, 2016, 01:57:53 pm Did you buy a kit? There was a plug and play kit available at one time.
Title: Re: Mustange tri-light break lights Post by: aaron88 on October 01, 2016, 07:00:20 pm Yes there was something, not sure if it's still available, but I do know that dguy installed something like that on his Fiero.
. Title: Re: Mustange tri-light break lights Post by: dguy on October 01, 2016, 10:40:54 pm Yes, I nstalled a sequential turn signal on our '85 many years ago, (arguably) before it became a "thing" on Mustangs.
It was a relatively simple task - the notchback Fiero's three parallel-wired 2057 bulbs original connection to the rear light harness was cut, such that each ended up having a separate connection to the sequencing module. If my memory is working there really wasn't much to the install if you are comfortable with side cutters and a soldering iron. Title: Re: Mustange tri-light break lights Post by: can machine on October 03, 2016, 07:10:00 pm Just happened to see this on Pennocks
http://www.webelectricproducts.com/products.htm If you look under the sequential tail light section they have ones for fiero's Title: Re: Mustange tri-light break lights Post by: Dan on October 04, 2016, 07:23:40 pm have them on my 88 formula and like the looks
Title: Re: Mustange tri-light break lights Post by: monzaguy on November 25, 2016, 12:29:13 am the new mustang tri tail lights are NOT adaptable to our cars PERIOD. Maybe off an 86-89 cougar,T bird.etc would work with a lot LESS werk
